1 - 10 of 10 Posts
Sorry if this has been covered before but what engine oils are you using in the V6's?
20W40 semi syn from local motorfactor (not the cheapest one the do) and replace it and the filter every 5K.
Regards
Yeah, you could put 20w/40 oil in - if you can find such a grade - but it'll knacker your engine. :rolleyes: I'm sure Shoggyraminator meant 10w/40 semi.
And changing the oil every 5K is worth it if you constantly drive hard. 8-10k is fine with normal(ish) driving. As long as you use good quality oil. In my opinion you can't go wrong with Shell Helix Plus 10w/40 semi. For £24 a gallon it's a bargain.
10w/40 is great, but if drive it hard and get the engine real hot then 10w/40 doesnt perform as good and sounds ticky, so u can go for 10w/60 Shell Racing oil fully synthetic or castrol RS 10w/60 which performs well when engine gets hot.
I like to drive pretty hard so I might be better with a 10w-60, but as it's so cold up here in winter maybe I should use 5w-40?? :confused: My average drives are around 20-30 minutes long if taking into account journy to work.
I didnt really think about your location, if you warm the car up before you drive im sure 10w/60 shud be more than fine, 5w/40 fully synthetic wouldnt do any harm either just doesn't protect and perform as well when the v6 gets hot and ur constantly flooring it.
I asked the same question a while back, and got the Selenia answers..... but my local mechanic told me that I should not change out the oil with a different grade, but should replace it with the same grade oil.....
Is he right? I wanted to put a 10w/60 in, but he reckons the oil currently in is 5w/40.....
The 10w60 would have been fine.
1 - 10 of 10 Posts
