I've had no response from Magnecor and haven't been able to find which cables (serial/code) I need for a 1988 33 1.7 QV 8V Dellorto 40 carb.
Can anyone assist?
I'll be in Dallas for 5 weeks and would like to bring some back with me but the suppliers are asking for code numbers from Magnecor!! As they won't reply I'm a bit stuck.
I only see lists for Spiders, GTV's Alfettas.
Can anyone assist?
For KV85 You should have part.no: 4501
Magnecor performance HT ignition cables
Select make: Alfa Romeo
No Of Cyl: 4
Model: 33 1.7 SOHC 8V (Carb)
Engine code: 305-50
Year: 1986-89
And you will find the info you need.:thumbs:
Just a thought.
It doesn't matter where the 33 originated from no? They weren't any variations in the ignition/engines for UK/Italy or other countries no?
1.7 Dellorto 40 1988 33 used the same cables/ignition throughout Europe?
Looking at the Magnecor cat. I can't see #4501 here. Are you 100% sure this is the correct one for my 33 model? Just wanted to check before I make a purchase that i won't be able to return.
4 CYLINDER (USA & Canada, see below for some non-US models)
1993-1982 Spider 40394 47394 45394
1981-1968 1750, 2000 GTV & Spider 4073 4773 4573
1979-1968 1750, 2000 Alfetta & Berlina 40394 47394 45394
1972-1955 GTA, GTA Junior, GTA 1300 refer
1970-1955 1300, 1600cc twin cam (except GTA models)
-- 33" coil wire 4073 4773 4573
-- 23" coil wire 4004 4704 4504
-- 15" coil wire 4092 4792 4592
many thanks
Discussion Starter #7 (Edited)
Got it now:) I see in the cat.
The USA shop will make them to these UK specs:):):):)
71 bucks, made to order in 1 week and sent to my hotel. Great.
