· Registered
I'm trying to buy new front discs and pads for my 2002 1.8 TS Sportwagon and am sure I read somewhere the discs on the Sportwagon were different from the saloon. I've been in touch with BuyPartsBy and because they are not Alfa specialists want me to measure the discs, check if they are vented etc which I think they are. However I don't trust my measuring skills, there deals are too good to pass up and know many people on the AO forum use them so here are are my options below. I'm pretty sure the vented discs (option 1 in brake disc section) are correct for the car but what about pads? Running 205/55/r16 on stock 16" lusso alloys if this helps, not the pepperpot ones but these ones in the link below http://www.ebay.co.uk/itm/ALFA-ROMEO-156-16-lusso-ALLOY-WHEEL-2002-2005-/190403731393
Thanks in advance
BRAKE DISCS
OPTION 1
Front Brake Disc
Part Number:BG2512
Type Vented
Description Brake Disc
OE System Continental Teves
Sizes (mm) Dia: 284 x Thickness: 22, 5 Holes
Engine CodeAR32201, AR32205
BHP 144
This part will fit the following vehicle(s)
156 1.8 932 (1998-2006)
OPTION 2
Front Brake Disc
Part Number: BG3420
Type Solid
Sizes (mm) Dia: 281 x Thickness: 15, 5 Holes
Engine Code AR32201, AR32205
BHP 144
BRAKE PADS
OPTION 1
Part Number: MDB1934
Description Brake Pads
OE_System Teves
Note Thickness: 19,3, Width 1: 155,1, Width 2: 156,3, Ht 1: 59,1, Ht 2: 63,8
Fitment to construction year: 02/2000
Fitment_2 with integrated wear sensor, WVA No.: 23140, recommended accessory kit: MBA1180
BHP 144
OPTION 2
Part Number: MDB2068
OE_System Teves
Note Thickness: 19, Width 1: 155,1, Width 2: 155,1, Ht 1: 61,7, Ht 2: 58,9
Fitment from VET Number: 383456
Fitment_2 with integrated wear sensor, WVA No.: 23289, recommended accessory kit: MBA1180
BHP 144
OPTION 3
Part Number: MDB2132
OE_System Teves
Fitment from construction year: 03/2000, to VET Number: 383456
Fitment_2 with integrated wear sensor, WVA No.: 23141, recommended accessory kit: MBA1180
BHP 144
· Registered
I've you've got 284mm vented discs and the Teves calipers then the pads are MDB2068 (I've only just done mine).
Mintex refs: Discs MDC385, Pads MDB2068 for front
hth!
PS I think SOME of the 1.8TS models had solid discs but AFAIK the sportwagon and saloon generally have the same brakes unless someone knows otherwise?
· Registered
The 1.8 and 1.6 had solid disks on the front only on pre Jan 2000 cars. Check the build date of the car rather than date of first registration if you are unsure as many Alfas sat around for some time before being sold (years in some cases!!)
