1 - 10 of 10 Posts
Right I've got my 166 back after 32 days! It was so good to drive it again.
I switched the engine on and just let it idle for about 15 minutes as it hadn't run in a month. However there is the distinctive smell of fumes and when I look at the exhaust pipe I see the cat and mid pipe are hinging down slightly. I also know that the attachments on the engine side of the cat have rusted away.
So it looks like I'll be needing a new one. lucky buypartsby come to the rescue!
I can buy a cat for £203.67 with a ceramic internal monolith. (whats a ceramic internal monolith?)
or I can buy one for £376.99 with a 376.99 stainless steal internal monolith.
Or if I've gone completely daft I can buy one for £565.80!
Now I'm very tempted by the £200 pound one as I can sneak it past the wife. Will I regret buying a ceramic internal monolith? (as far as I'm aware that's a big hairy elephant with tusks)
Oh no here its is
http://en.wikipedia.org/wiki/Monolith
No sure why I need one in my exhaust. It doesn't sound very sporty?
Cheers Stuart
I've been looking around for the 64 and have found Uni-Fit to be a very tempting option. I bought a system from the cat back for the Daewoo mother ship from them and am happy with it so I imagine I'll buy from them eventually as the alternative is, as you've seen, very expensive in OE guise.
You only need a new one if it fails the emissions or falls off the car.
It probably jist needs a guid run.
Laceys full new system sailed its emissions today.New cat and new lambda front pipes too.
Also rock all wrong with a ceramic cat.
Pomeo
Cannot dump the cat and run an open box instead with a connection for the O2 sensor ? as long as O2 sensor is connected and works,your CO will be 1 or under..is that enough for the MOT ?/
Power wise you will be corrupted..:)
1 - 10 of 10 Posts
