Which Alloy Size?
596 Views 5 Replies 2 Participants Last post by  Spacecadet
Hi there,
i am going to be fitting a new set of wheels to my 96 2.0 16V Super, before i do the car wheel be dropped by 35mm on eibachs.
i need to know which size of alloy will fit the best so that i wont get any scrubbing even with a full boot and 5 people in the car.
im thinking at the moment of 17" J7 with 205/40,
or would 16" be safer?
ilso i have been reading that wheels of 100pcd will fit without a problem if used with "varibolts", i have never come across these before, does anyone have any info on them? will i need to replace all 16 of them?
cheers guys- any help is greatly appreciated
You shouldnt have any problems with 17" as far as I know (perhaps a little rubbing on full lock if you're unlucky).
Varibolts-you'll need all the bolts but Henry has kept the locking nuts and it seems ok. Your local Halfrauds can help out.
wrinx
My V6 runs on varibolts, I got them from an internet firm
Look here
Trackstore
The ones you want are called sb21V.
I found that I had to cut them down by 3 mm on the front to get a good tight lock, it would seem that a set of spacers my car should have had have disappeared.
I used Honda spec wheel with a shallower drilling so the 3mm got rid of the extra length caused by the shallow bolt holes.
These bolts are exactly the same length as the originals and cost £25 delivered.
Andy
See less See more
cheers guys, now the difficult bit, deciding which wheels would look good!
andy, check your PM's, you may have one waiting from me.
Jack
Eibachs on mine and 215/40/17 tyres. Works a treat with no catching :)
See my little old entry in the pictures lounge. They are TSW Imolas, lovely wheels, the multi-spoke design works well with the 155s slab sides!
