1 - 16 of 16 Posts
· Registered
Well if you are still interested in getting this stuff GTV wheel bolts
I have someone who mighty have for sell you can kindly text him on his gmail address
[email protected]
Good luck
Sent from my Infinix X559C using Tapatalk
At the risk of suspecting an innocent person, your forum name and the Gmail contact you suggest are both awfully suspect. Not to mention a poor grasp of Engrish for a pair known as "alexjohn" and "johndaniel". Oh ... and the relatively fresh membership (2 months) and absolutely no prior posts ... nor a profile of any sort.
I say this as someone who has seen a few of these come and go on AO. And had one try to scam me apropos a Squadra chipset (needless to say it did not get beyond some suspect messages sent to me...).
I will apologise to all if I am being a little otherwise here. Just have little humour for take-a-chance types.
Victor Meldrew.
· Registered
Discussion Starter · #7 ·
I did likey the message but thought it might be unlikey to get bolts - I just want some new bolts for the wheels - thanks for offers of used ones but I have used ones on the car already. Can anyone find a new set that would fit????
· Registered
Discussion Starter · #8 ·
Victor Meldrew.
· Registered
Try these on Ebay. I received a set of 20 today and they are almost identical to my old ones give or take a mm or so in the overall length and thread length, which is irrelevant. Unlike the ones I took off they are threaded along the whole length of the shaft but this won't matter either. They have removed another photo which claimed the HEX size (the spanner size needed to remove) as 17mm unlike the description lower down which states 19mm which is the size of my old ones. The ones I have taken off (a yearr 2000, 3.0 V6, CF2 with 17" Teledials) were M12x1.25x33 with 19mm HEX. (i.e. 12mm thread diameter, 1.25mm thread pitch, 33mm shaft length measured from the tip to the start of the taper) The total length was 59mm but this is less important. I would suggest you phone and double check the details with them before ordering. I did. Hope this helps.
· Registered
Discussion Starter · #10 ·
Thank you that’s very helpful - will have a look, much appreciated!!
· Registered
Discussion Starter · #11 ·
Set ordered!
· Premium Member
Brera 1750TBi (2010)
Personally I just noted the specs and ordered quality bolts the length I want (I do use spacers) from the local shop which specializes in wheels. You can even have them in black if you want. Not that expensive either way.
1 - 16 of 16 Posts
