As the question suggests, where is the temperature sender that operates the temperature gauge on a 156 1.8 Twin Spark (CF3)?
Is it the sender that screws into the top of the thermostat?
Just wondering...
There is only one temperature sensor, which is the one in the thermostat housing.
OK - the new thermostat is working perfectly and the engine running at perfect temp (fan cutting in etc) according to multi-scan diagnostics.
The temp gauge still only normally reads on the line between the bottom and 90 degrees. No big deal as it's all running properly but just a niggle.
Would it be worth changing the temperature sender on the stat to try and stabilise the temperature gauge (as most new thermostats don't come with a new sender)?
Are they easy to change/fit? Anything to watch out for (apart from disconnecting the poxy plug!)?
TIA
There is only one sensor housing on the thermostat so it looks like 1 sensor, however, this contains 2 seperate sensors, with seperate electrical connections in the plug. One for the ecu, one for the temperature guage.
