ANYONE KNOWS WHERE IS A HOLE TO RUN THROUGH A CABLE FROM THE MOTOR TO THE INTERIOR ?
OR I´M BLIND OR THERE IS NOT.
REGARDS :(
Hi there Jorge,
I think there should be a hole in the upper corners of the engine compartment, under those moulded spunge things, but I am not near my car to check.
Regards
Jacques
george
chechout alfa155.co.uk - henry yorke's web site.
go into tech info. ann there's some pictures of the hole where the wiring goes through.
good luck in your quest!!
J
I just had a radio fitted and they had to remove the windscreen wipers plus the plastic beneath them to get to that hole.
(For the 12v wire from the battery.)
It ends in the compartiment left of your steering wheel covered with a plastic piece.
Hope this helps.
Good luck, Jan.
