I have a 146 2.0 TI . The problem is the heat selector knob does nothing ! and is set about midway meaning pointless AC cooling and rubbish heat output first thing in the morning. When you turn it you can hear it rasp which would indicate the splines on the end of the shaft are jumping and whatever this should be turning is not turning ? I don't know the setup here so don't know where to start in disassembling - Please help - any pictures of the assembly would be really useful.
IIRC, there are a few screws holding this panel in. If you removed the 3 knobs by simply pulling on them with some plairs (wrap cloth around them not to damage them) that should reveal some screws, un-do those, then i THINK there is one behind a cap on the bottom right of that control panel, and then, im not sure as i am at work so cane reference anything, but may be one to the upper left of the panel behind the leather strip gaurd thingy, this guard simply pulls off. Then you should be able to see what is what.
