1 - 9 of 9 Posts
Had both front door cards/inner panels off on the 147 to sort the window up/down action, sorted that, but noticed the Tweeters seem to have flown! The wires/plugs are there on both sides, just hanging! Anyone else found this, or am I the only lucky one? It says tweeters in the manual for the Bose setup. I want my Tweeters!:mad:
Hi Zulu.
The Bose system doesn't have separate tweeters. Its just the standard stereo that does, so your "tweeter" holder in the door panel should be empty. Panic not! This is the way it should be!:)
Just wish the wires were labelled "Goes Nowhere To Nothing Don't Worry." Exactly the same with the Thema. Don't remember it so much on the FIATS, probably more cost conscious!
N
Don't worry ZF, your tweeters are there!
Bose just decided to make them "co-axial".
So if you look at your woofers you'll see
that they have the tweeters mounted "in" them. :)
1 - 9 of 9 Posts
