No, nothing like that, although they are 60 miles away so not easy to just pop in. I'll email and ask, I wanted to take it to a local garage and buy the oil myself to give to the mechanic so I know its the correct stuff.Didn't the dealer ask you to drop it in for post run in service and check? Normally about 1000 miles
The first service is due after 12 months but only a visual check. If your vehicle is incurring more difficult conditions you can have the oil changed at that time. I did & it cost about £150. As far as a check after 1000 miles is concerned, I'm pretty confident there isn't one. You might get the dealer doing a courtesy call to see if everything's ok but nothing more. Oh, cost of the first service 'visual check' was about £90 - £100 without the oil change. Mines done just over 16000 miles now & it just keeps on getting better!No, nothing like that, although they are 60 miles away so not easy to just pop in. I'll email and ask, I wanted to take it to a local garage and buy the oil myself to give to the mechanic so I know its the correct stuff.
Thanks cue, therein lies the dilemma as I have read many pieces of advice. Do you leave the good first oil in with its special ingredients or get rid of it with the pieces of engine shavings circulating around the system doing god knows what damage....?Our Belgian Giulietta man on here who is a main dealer mechanic wrote recently about oils and suggested the first oil from new is different from replacement / servicing grade. I may be wrong, but I got the impression he was suggesting it's good to leave it in for a while, like until the first service. It may perform better some function which requires it reaching a certain age. New oil is not so protective or some such theory. I'm sure he will explain if I've got the wrong message from what he wrote.
It's ingredients that are missing... friction modifiers (to lower fuel consumption) hamper the running in process.Thanks cue, therein lies the dilemma as I have read many pieces of advice. Do you leave the good first oil in with its special ingredients or get rid of it with the pieces of engine shavings circulating around the system doing god knows what damage....?
I wouldn't worry too much about the brand of oil, dealers will use Selenia as they get told to, Havolene is just another half decent brand. Anything that meets the guidelines should be fine.What oil make do you prefer? I keep putting Selenia oils into my baby but I have noticed the indies seem to prefer Halvolene?
i wouldn't either except if we are considering selenia star pe 5w40, which is poor oil(i won't be getting into details why). other selenias are ok or good or better. agree, no point to get crazy about oil brand(e.g. some people would use redline or ams or search for only pao/ester based oils(true syntetic, not to ones often called synthetic, but really hydro-cracked oils without decent additives etc)), i would go for decent enough hc at least, eg i use motul xclean 8100 5w40 c3 for my wife's giulietta 1.4tb 120bhp, easy available, not that expensive, good enough. millers are considered good as well, in uk should be also easily available. most important are oil change intervals, i use rule 10kkm of city drive or 15kkm of motorways, or every year, whatever comes first. first oil change in giulietta i did after a year @ 5.5kkm mileage (this was at dealer and so they put selenia star pe), second (just after warranty expired) i did engine flush, put motul and added archoil 9100 additive (do not add such too early, eg to new engine, some minimal breakin process still needs to happen)I wouldn't worry too much about the brand of oil, dealers will use Selenia as they get told to, Havolene is just another half decent brand. Anything that meets the guidelines should be fine.
If you have the choice, I'd use a cheaper oil (that meets all the specs) and use the price difference to change the oil more regularly.
I had the factory fill in mine, then castrol edge turbo diesel 5w-40, then the dealer fill (total quartz ineo mc3) and currently using a mix of all leftover I had (castrol magnatec professional oe 5w40, castrol edge turbo diesel, Shell helix ultra turbo diesel 5w-30).What oil make do you prefer? I keep putting Selenia oils into my baby but I have noticed the indies seem to prefer Halvolene?
well, since you mention it...i wouldn't either except if we are considering selenia star pe 5w40, which is poor oil(i won't be getting into details why). other selenias are ok or good or better. agree, no point to get crazy about oil brand(e.g. some people would use redline or ams or search for only pao/ester based oils(true syntetic, not to ones often called synthetic, but really hydro-cracked oils without decent additives etc)), i would go for decent enough hc at least, eg i use motul xclean 8100 5w40 c3 for my wife's giulietta 1.4tb 120bhp, easy available, not that expensive, good enough. millers are considered good as well, in uk should be also easily available. most important are oil change intervals, i use rule 10kkm of city drive or 15kkm of motorways, or every year, whatever comes first. first oil change in giulietta i did after a year @ 5.5kkm mileage (this was at dealer and so they put selenia star pe), second (just after warranty expired) i did engine flush, put motul and added archoil 9100 additive (do not add such too early, eg to new engine, some minimal breakin process still needs to happen)
