A pedanticalness I resisted!To, Too, Two - The Easiest Way To Learn How To Use These Words
To = Use to as a preposition before a noun or as an infinitive before a verb.
Too = Use too as a synonym for also or to indicate excessiveness before a verb. Usually, if you can replace too with also in the same sentence, and it still makes sense, then you are using it correctly.
Two = Use two to spell out the number 2. If you can replace two with 2 in the same sentence, and it still makes sense, then you are using it correctly. This should be the easiest one!
If a 3.2 166 crossed my path I'd probably say yes.....rxe needs a 75.
Add a Montreal to that list!All I really want is an Alfa 90 Gold cloverleaf an Alfa 75 3 litre oh and a Alfa sz, not much to ask.
This ^^^ :thumbs:Add a Montreal to that list!
I've sold a Carcoon fan on eBay (it was from an old Carcoon I tore and binned). The owner noticed my name on eBay which has Alfa in. Anyway he preceded to tell me it was or is an Alfa in the Carcoon. He revealed just yesterday that it is a Montreal and that he has had it for 15 yearsThis ^^^ :thumbs:
yep. Rover 75 that would berxe needs a 75.
