Hi.
I have a set of 18 inch OZ Ultraleggeras on my Mito, and wanted to fit spacers in the rear. I therefore measured the distance from the inner fender lip to the tire, using a hanging weight and a ruler. This gap basically: http://wheels.acuteperformance.com/images/spacer_measure.jpg
I discovered that there was a BIG difference in how big the gap was on each side of the car!
On the rear left side there is a 30 mm gap and on the rear right side there is only about a 10 mm gap. What could cause this? And is this normal?
I did replace the rear wheel bearings not that long ago, but I didn't have any problems getting them fitted to the car.
Any help is appreciated!
Are you sure the 10mm side doesn't already has a 20mm spacer mounted? Are the tires/tirewidths the same on both rims? Are the rims the same width, same ET value?
If so... did your car had an accident at the back? :paperbag:
Just a thought: when you are using gravity to define your measuring datum, it's very very important the car stands on flat ground.
The rims are the same and there are no spacers fitted on any sides.
I asked about this on a general car forum, and several people stated that their car was the same. I guess it might not be so uncommon... Some people also suggested that it might be possible to adjust the whole rear suspension a bit towards the left. I might have to have a shop look at the car since it also pulls slightly to the right.
