which size should i get? I'm getting a new set of tires for it but i don't want to change the original alloys, I'm getting low profile but there rather thin so i wanted to bring them out a bit would it help the handling...?
As said above DO NOT change the size of the tyre if keeping the original wheel unless its making a 215 fit instead of a 205 but u must keep the profile (therefore diameter) the same. Buy a half decent set of tyres and then pop your spacers on and you should notice a difference but if it a lower car you want buy some sport springs!!the alloys are 16" tires 205/55ZR16 i was just looking into doing something with them, i like the original alloys so i don't think i want to change them but i would like to change the tire size getting a lower what size should i really be looking at? or would they really make any difference other then the look? i would like to improve the handling and i just thought id take the chance since my tires are in dire need of replacing, thanks for all the reply's they are appreciated.
Exactly that.Are you referring to the amount of thickness of the metal between the flange and hole? I have come across this opinion on another forum, but was not convinced. Would love to know your reasoning/ experience of this.
Steering feel is fine.Good to read you can squeeze in 15mm spacers on the factory 16 " wheels and clear the arches. Do you have any difference in the steering feel, compared to standard?
