hi guys
can anyone tell me what length bolts I will need if running 10mm spacers on my 2001 x reg 156 1.8TS. 16" rims 5 stud. would it just be 10mm over standard bolt length?
thanks.:read:
For starters, I wouldn't use 10mm spacers because there isn't enough metal for the hubcentric bit to be strong enough.
Safer to go to 15mm.
But to answer the question, yes just add the spacer width to the std bolt length.
Std wheels use 23mm bolts (tip to start of taper), so, for example, a 15mm spacer would use 38mm bolts.
