1 - 20 of 21 Posts
I've been on the look out for a brush, or two, to use on my 159's alloys but all I can find so far (haven't looked that hard yet, tbh!) are brushes that have a plastic-coated wire core (like a large pipe-cleaner) that I'm sure could easily damage your wheels once the bristles get worn or earlier if you're not careful.
Must admit I've only looked in Halfords and on Amazon while in & on there, but before I start looking at the specialist sites, anyone found anything safe and easy to use? I have the 19" spoked wheels so the brush would need to be quite narrow to get between the spokes.
Or should I just use a mitt?
Thanks in advance :biglaugh:
Administrator
Sonic Scrubber if you're feeling lazy.
Depends how much you car about your wheels.
I can higly recomend one of these: Valet Pro - Inch Round Wheel Brush - Clean Your Car with some of this: ValetPro - Bilberry Wheel Cleaner - Clean Your Car dilution ratio means it lasts ages!
No "scrubbing" required and non acidic unlike some cleaners. Brush is soft so wont mark alloys.
Bilberry wheel cleaner is great but either Bilt Hamber Auto-Wheel or Bilt Hamber Korrosol are better by miles. I made this video on a customes extremely filthy wheels (not been cleaned in about 6 months so Korrosol was the better option). No pre washing and the inside of the rims were spotless too. No brushes, no agitation and spotless wheels in under two minutes...
It's also water based and PH neutral.
https://www.youtube.com/watch?v=8M9tC00EIqU
Here is the Auto-Wheel in action on my Blackline wheels, I use this on moderately mucky wheels..
https://www.youtube.com/watch?v=M_4OwFy9M7g
I had a brush as you describe ,with the metal wire in the spine , and it rusted snapping into a pointy handle which damaged a spoke of the wheel I was cleaning. Better off with a plastic brush!
The Korrosol can be used all over the car to remove bonded iron contamination, even on glass and plastics. If you use it before claying it means you use less clay.
Tommy, can I just steal all your stuff?
The list of goodies I want is growing faster than it's shrinking, and YOU'RE THE BLOODY PROBLEM :D
1. Bilt Hamber Clay
2. Korrosol
3. Cherry Glaze
4. Organic contaminant remover (I'm sure you'll have a suggestion for me ;) )
5. Detailing lance and BH Autofoam
But I do now have a nice red fluffy towel by your recommendation :thumbs:
Good to know :thumbs:
From the look of the datasheets, the glue/tar/organic removers are also going to strip wax pretty effectively too? Are these generally a once/twice a year job when you do a deep clean?
Yes, they will strip most waxes. I use it on the bodywork when I'm doing a full decontamination (tar & glue, fallout remover then clay), so probably twice a year at most.
I use it on wheels more frequently though as they require decontaminating more frequently.
Check out wheel woollies they are highly regarded on Detailing World
http://www.wheelwoolies.com/wheel-woolies-kit
I use the brushes that came with the AG wheel cleaning kit, they are a little small for the 19" wheels but they have been good so far,
I bought a big soft noodle cleaner from halfrauds last time I was in to make it a bit quicker and that also seems good
Bloody hell that's impressive stuff. Wheel cleaning is my least favourite bit of the process so I think I'll be having some of that.
Thanks for sharing.
  • Like
Reactions: Tommywho156
1 - 20 of 21 Posts
