Changing my not so nice wheels on the V6 for a nice set of Teledials:yes: I have purchased. Do I need different wheel bolts? If so please can someone tell me what length, I'm assuming M12 x 1.25 + Length and any recommendations for locking bolts would be useful. Do I need spacers or will they fit straight on. Thanks guys.
If they're the correct 916 Teledials ( 30.5mm offset ), they'll fit straight on with the standard bolts.
Thanks PKR. They are the correct 17 inch 916 Teledials. A few pounds saved to spend on her elsewhere. :biglaugh:
Depends what wheels you have now and what bolts they are currently using.
The std GTV wheels use bolts about 38mm long (tip to start of taper).
The ones the car came with are the Standard 16 inch wheels that have the 5 circles, I'm not sure what the correct name is. Sort of a teledial but not the same as the 17 inch teledials. I'm just finishing giving them a good clean. They have a little bit of kerbing but not to bad and they won't get a full re-furb until next year as Cam belt on the V6 is required and my Spider is having a new hood next month :yes:
