can any of you technically minded boffins tell me the non factory cambelt angle and wheel alignment settings for 2.4 ti model seemingly this would help prevent excessive wear on inside of tyre possibly clutching at straws here but you never know
Presume you mean camber, not cambelt!
Camber is not usually adjustable, but isn't the cause anyway.
Just set the front tracking to parallel (ie 0mm).
I was told by Alfa UK that the camber on my 159 had been out at the factory, and was causing my early tyre wear. It was corrected, so I assume it is adjustable.
I suspect they just adjusted the tracking.
Doesn't look like any way of adjusting the front camber.
Looks like Rear camber is adjustable though. At least, AutoData says it is.
