1 - 20 of 39 Posts
· Registered
I thought there was already a thread about this but I can't find it, plus my to do list is so long that it deserves a thread all on its own :cry:
  • Replace the rocker cover gasket (it might be worthwhile changing the spark plugs at the same time).
  • CV joint boot replacement
  • Oil and filter change
  • Probable new exhaust section (it is blowing a bit and while I quite like the raspy sound at the moment, I need to get it on a ramp to look at where the hole is before it gets any worse)
  • New bushes (maybe powerflex) on the rear
  • Replace the spring pan arm on the rear with either a new or reconditioned unit (I guess I'll do this at the same time as the bushes).
  • 4 Wheel alignment / tracking
  • Replace the passenger's side window motor.
  • Install a new electric arial
  • Cambelt cover needs replacing
  • Sort out the intermittent wiper problem
  • Fix the rear window de-mister (it's never worked in the 2.5 years that I've had the car)
  • Fix the air conditioning (it has a leak somewhere)
Phew!All this to do and that is before anything goes wrong (and I haven't mentioned replacing one or two of the tyres either....) Should I just get a new car and be done with it?
· Registered
Oooh..
Cambelt change + aux belt + tensioners - cambelt is overdue based on time. not sure when the aux belt was ever done
Front wishbones + drop links + track rod ends + fix the totally seized track rod adjuster nut
Springs and shocks all round
Aircon doesnt work either
Door mirrors need respraying
Cross fingers and toes thats it.. :lol:
· Registered
Good point, I have replaced / serviced a few things on the car:
A new set of discs and pads on the rear
1 rear wheel bearing
Rear shock absorbers
The cambelt, variator, water pump and other associated gubbins.
Front wishbone
Various exhaust parts
A front brake hose
Clutch slave cylinder
Bled the brakes
· Registered
Rear spring pans and arms to re-bush, new bluetooth stereo, mirrors to change, alloys to finish refurbing, and a full respray!!
· Registered
Not a short list :)
Major Items/To be done soon stuff
Front Discs and Pads : Done!
Shock Absorbers : Done!
Oil Change Done!
Coolant Change Tommorow
Change gearbox oil Done!
Replace Clutch, Thrust Bearing on it's way out
Replace Thermostat (Doing that tomorrow)
Driveshafts – Driveshaft lose (drivers side) Worn (passenger side)
Replace both front lower wishbones
Replace Rear Brake Pads (Stuck/Squeaking/Low)
Underside : Needs cleaning/underseal
Replace Front Brake pipes (Ends corroded)
Probable : Replace clutch slave cylinder (Oil Leak)
Exhaust pipe, mid section support fell off left a hole (Patched for now)
Work out what strange clunk is when changing down from third to second
Minor/Long Term Items
Cam Belt
Aircon : Non Functional
Laquer peeling from paint on rear wing.
Wind Noise from both Doors
Front Tweeter speakers fallen out
Doors not shutting properly (sometimes close but cant open from inside)
Trim Loose in boot
Plastic covers in engine compartment broken
Do something about the 100+ stonechips on bonnet
Do something about the scratches on the side panels/roof
· Registered
Koni's all round
Fit braided hoses to brake lines
Rear disks and pads
Paint callipers (all round)
Remap still on the agenda
Tidy up the 15 year old paint!
Will probably get this all done over the winter months.
I want to enjoy what little summer we have left :D
· Registered
I've already done a few bits since owning mine:
Rear brakes sticking - done
inner spring pan bushes - done
Thermostat - done
Clutch slave cylinder - done
O/S inner CV boot - done yesterday
Still need to sort out some dodgy paint on N/S door, rear quater and bumper - hopefully get this booked in to be done this week :)
Then...just need to find someone to buy it so I can have that Zoe Yellow 145 Cloverleaf for sale on Pistonheads!
· Registered
Front wishbone
A front brake hose
Bled the brakes
Don't you mean OUR to-do list :lol:
· Registered
I can live with the damage Starkers - it hasn't damaged the paint much but the dents are pretty deep. What really ****** me off is that this old girl was in really nice shape - not show condition but good nick for a ten year old.
1 - 20 of 39 Posts
