You got any pictures of what the LED replacements looked like mate?The bulbs are a dual filament W21/5 I think. I bought some LED replacements for the running lights. They looked really good but the different resistance of the bulb causes an error on the cars computer and reports a bulb our on the display
So I gave up and still use the originals
To be honest all this ohms, volts, amps, current, resistance etc I forgot the day I no longer needed it. i.e when I was 18 years old, wish I could help, and wish I could actually remember any of this. If only when I was 18 years old that 8 years later all that information would actually come into useSorry i took them out stright away because of the dashboard warning. Each bulb has 18 high output leds on it (5 rows of 3 round the side and 3 lensed LEDS on the top). they are the same type of LED that you get on mobile phones as a torch or flash. The only way I can see for them to work without the warning on the dash is to put a load resistor across the terminals on the bulb so it has the same ohm rating as a normal bulb (Hmm might try that...).
Just need to know the resistance of a 5w 12v bulb, which I think is voltage over current. A 12v 5w bulb will draw a max of 2.5amps (please someone correct if im wrong on this!). I think R = V/I which would be 12/2.5 = 4.8 ohms as a loading resistor. so with that load across the terminals of the bulb the computer should think its a normal bulb.
If this is right ill get the resistors, fit the bulbs and take soem pics as they are extremely white!
I really want tog et these bulbs working
The bulbs were only a tenner. ill see if i can find some resistors tomorrow and try it.... Watch this space!To be honest all this ohms, volts, amps, current, resistance etc I forgot the day I no longer needed it. i.e when I was 18 years old, wish I could help, and wish I could actually remember any of this. If only when I was 18 years old that 8 years later all that information would actually come into use(Not much use for all that malarkey for my career path)
If you get it to work then pop a picture and tell us folks how to get it work, the LED lights sound cool! How much they cost you?
Great! Thanks. I thought my maths was a bit off! ill get some resistors and have a go later.5W is between 350mA and 430mA (12V vs 14V) and equates to a resistance of between 29 and 39ohms.
If you put a 4.8ohm resistor across 12V (up to 14V+) then it will have to disipate between 30 and 41Watts - that is a fair amount for a resistor.
To model a normal filament blub using an LED and a resistor you need to statisfy the equation R = 144 / (OriginalBlubPower - LEDBlubCurrent*12).
GK
Looking forward to results mate! :thumbs:Great! Thanks. I thought my maths was a bit off! ill get some resistors and have a go later.![]()
might be worth a shot being so cheapJust come across these on the fleabay, are they similar to the ones you have mate?
Thanks for the update! Just think, it will be worth it though! :lol:The ones I bought are turning into a bit of a mission to fit. Got the load resistors to use with the bulbs to ensure that the computer registers a bulb in there. The second problem is due to the multiple connections to deal with the dual filament bulb that is in there. The LED bulbs cant be used with a dual filament connection so you can only wire them for side light or Day Lights only, they wont work for both. Gonna have a mess around this weekend and take some photos to put on here and see what u think.
Been looking at this aswell, if you want to fit something for day and side light then your going to need a stop/tail light replacement LED bulb,The ones I bought are turning into a bit of a mission to fit. Got the load resistors to use with the bulbs to ensure that the computer registers a bulb in there. The second problem is due to the multiple connections to deal with the dual filament bulb that is in there. The LED bulbs cant be used with a dual filament connection so you can only wire them for side light or Day Lights only, they wont work for both. Gonna have a mess around this weekend and take some photos to put on here and see what u think.
