6181 - 6200 of 6213 Posts
What’s the best size speakers front and rear in the 156 and which check straps did you use out of interest (one)?
depends but standard size is 16.5cm iirc and has a hole for a tweeter ... so components are usually the way to go ... if your going for a decent sound stage i usually just leave the rears off unless i have rear seat passenger so just a cheapish set if any... really decent deep speakers wont fit in the plastic holders so its difficult to know whats the best that will fit really
I’ll have to take them out and check. I’ve found some reasonably priced 16.5 cm 2 ways by Blam audio, but they are about 62mm deep from the back of the mounting surface and I’ve got not idea if they’ll fit.
Not after anything too fancy, just 2ohm as the Bose sound tired and only work when turning them up - but could just be connectors that need cleaning from a search result.
Had the 4 wheel alignment done, drives really nice now never had the tracking done since getting the gta in 2016 as was waiting to finish suspension updates, refurb alloys and new tyres
Took the 156 GTA out for a drive today (not my daily). I’ll never get tired of it!
Decided to keep the climate control off and open all the windows. Slightly confused about closing the back ones on the way back - or my hearing was out whilst driving. Turns out the switches work the wrong way around. Not had the car long.
I guess it’s another reason to take the doorcard off and replace the check strap!!!!
Is it a sports wagon? Mine do that too. I thought they were broken, until I accidentally pulled the swith one day and one went down! Very confused but at least they work lololol
It’s a saloon. Yes is caught me out but made me chuckle when I realised. I do have a door strap to replace - sometime this decade the rate things are going with how much spare time I have I just want to drive it. I might just leave it like that for a laugh. Good talking point about Alfa electrics to non-Alfisti!
Cars off the road due to failed alternator so decided to have a go at removing the gunk from the centre console.
Used alcohol, caustic soda, panel wipe,
Meths and they were all totally useless.
So experimented with an unlikely product which is ‘driveway concrete and masonry cleaner’🥴. Total transformation. Lifted the gunk off with a few passes with a load of microfibre clothes and just repeated.
I also cleaned the lumber support knobs that were super sticky. Again, after a few wipes, they come up
Brand new.
I made sure I rinsed off all the chemicals with a damp cloth.
958378
Took the car to MVC the local South Manchester Alfa specialist for the cambelt kit and auxiliary belt kit today. I’ve been waiting quite a while as they tend to manage the Busso workload and spread it a bit.
Got there at 830 only to be told the boss that normally oversees work on them is off on a last minute holiday and to drop it off on 17th September in 4 weeks’ time!!! Shame they didn’t call to let me know before I took car car out of storage at my mys house.
Might see if anywhere else within a reasonable travelling distance can do it sooner. Alfatune don’t seem to answer the phone so not sure if they are still trading?
Alfa 147 GTA
Mysterious fluid leak, turned out to be power steering fluid and pipe rubbing against cv joint?! booked into auto Alfa later in the month. also do the rockers which are weeping while it’s in. I’m hoping that will be the end of the work for a bit!
Alfa 147 GTA
Brand new.
I made sure I rinsed off all the chemicals with a damp cloth. View attachment 958378
I found tar spot and bug remover does wonders too For the nasty plastic gunge.
Went to use the car last week and even though fine the day before clutch disappered to the floor .. guessing i have a leak. havent been able to investigate this week as house bound due to covid..
Alfa 147 GTA
clutch slave or master cylinder is leaking. Hopefully for you it’s the slave, the master are like rocking horse poo and expensive!
yeah bought a slave just in case .. found a master if i need one for 34 quid but unsure of make. slave is a TRW part.. will hopefully have a look early next week .. thanks
Alfa 147 GTA
make sure the master is for RHD car, Lots around but most for LHD. They’re different due to bell housing being only on one side
I was looking for some feedback. My mind is made up but I was wondering what others thought on this was.
I'm going to get a private reg for the car. Its my 50th soon and I kinda thought is was a good idea. My wife also secretly had the same idea and I'm glad I mentioned it as she was going down the route of getting something personal to me.
I definitely want something personal to the car
I went with L50 GTA.
Thoughts!?
