1 - 20 of 37 Posts
Hi guys, I've nearly had my GT for 1 year now done just over 10000miles in it now and it has approached the 80000 mark. After nearly 1 year everything was going so well up until 2-3 months ago and now my wallet feels a lot lighter. So I thought I'd start this thread to see what other people have had done or had to do over the last year. So where to begin first of all I upgraded the stereo to a Sony mp3 with all the correct leads so I could continue to use my steering controls (cost me just over £100) and then the major costs started. New catalytic converter, New clutch slave cylinder, New clutch and fly wheel, New clutch master cylinder, gear box oil change, New battery, New wipers which all has cost me over £1000, oh and yesterday I had a hands-free parrot system installed which I'll get pics up for tomorrow. So yes what has everyone else had to do to their beloved GT
Upper wishbones
Meyle drop links all round
Replaced lower wishbone balljoint boots.
Front wheel bearings
1 x ABS Sensor - damaged when doing bearings.
Mtec grooved/dimpled discs and mintex pads all round
Painted calipers
Rear parking sensor
Mito heated washer jets
4 new tyres
Aluminium undertray
Plastidip door grab handles
120,000 mile service
Quite a list.
All the best
Pub
S
I Got My GT in April this year, Think I bought it on 54000 miles and its now on 61000.
Only major issue is when I got the wheels Powder Coated, 3 Alloys were Buckled so had to buy 3 second hand ones.
Since I Bought it;
Powder Coated Alloys
Powder Coated Brake calipers (and rebuilt)
Braided Brake Hoses
Koni Adjustable Shocks
H&R 35mm Springs
Meyle Droplinks on Each corner
4 New Swing arms at the rear
2 New Upper wishbones on the front (Powerflexed)
Windows Tinted
BMC CDA air filter
New Expansion tank
New Silicone Water hoses
Longlife Catback Stainless exhaust
Clear side Repeaters
And Undersealed
Pub - did you paint or spray on plastidip onto the door handles and do you have any pictures of the end result. Mine are looking a bit grim.
haven't done anything on mine other than keeping it going, wash and wax, fix some CTEK fly leads to it and treat it to petrol each week.
Steve
D
Got my GT in july this year, so far;
Clear side indicators
Egr blank and ECU delete
Belt and water pump
New front brake hoses and brake fluid change
Gearbox drain and refill with new oil
Injectors resealed
Spare wheel, jack and tools removed, can of tyre weld now used.
Bonnet sound proofing gone, saved in all about 50 kg.
Sprayed. Have a look at this thread.
Pub
Upper wishbones
Painted calipers
Rear parking sensor
4 new tyres
Aluminium undertray
Quite a list.
All the best
Pub
Were the mito heated washers an easy install and how much do they cost to get hold of? Would be ideal in this cold weather and frosty mornings
Bought it!!!!
Clayed and polished it
Cured the tailgate creak
Oil and filter change
Gearbox oil change
New radiator fitted
Painted the cam cover and cleaned the engine bay
Fitted new top engine tie bar
Painted brake disk hubs and re-lacquered rear calipers
Put fuel in it (lots!!!!)
Loved driving it :D
Piece of cake, just pop out a few of the poppers on the bonnet liner, pinch the old washers and push them out, connector for the heater will be nearby. They were about £20 each from my local dealer.
Do you have a link for the plastidip please?
It's just the spray can, bought it on eBay.
Good luck
Pub
D
What if the current ones arent heated, will there still be a connector somewhere?
Look at this thread
Connectors were there on the GT, can't say for the 147.
Good luck
Pub
Had a root about on my 147 and the connector is tucked in the loom near the NS strut turret so just have to run it to the bonnet to use them.
S
Look at this thread
Good luck
Pub
Was there ever an option to have any other Screen Wahser jets fitted ?? as on my GT I don't have the 4 jets of water I have a Mist kinda spray.
1 - 20 of 37 Posts
