^ That shine. 😎
Yeah they're terrible aren't they. I had no idea until there was a thread on upgrading them. Soon for onto Ali express for some upgraded bulbs.Fitted LED front indicator bulbs as the standard ones you literally cant see in the dark with dipped beams on 🤣
Are you saying there are two exhaust gas temp sensors on the 2.0 diesel or is that a typo?Replaced the straight egts on my 2.0, the awkward one under and behind the turbo.
Yes there are 2, a right angle one which is pretty easy to change and a straight one which now I have worked it out is relatively easy... Just not as easy as the other.Are you saying there are two exhaust gas temp sensors on the 2.0 diesel or is that a typo?
edit: so the s stands for sensor? It was the word straight that was confusing me as if you were making a comparison with a different shaped one!
I believe there is only 1 exhaust temperature sensor, on the dpf. Are you referring to differential pressure sensor or lambda ? Why were you changing it out of interest?Yes there are 2, a right angle one which is pretty easy to change and a straight one which now I have worked it out is relatively easy... Just not as easy as the other.
Maybe there are others, I don't know.
