Cool.I fitted a number plate light reverse camera and hooked it up to a rear view mirror with auto dimming with 4.5 screen. The auto dimmer is far better than factory fitted one. All cables clearly hidden, it looks stock.
??Collected it last night, put it on the drive this morning.
Thought I would jump in, got me a Giuletta this morning, 2.0 jtdm.
Not had a 'modern' Alfa before.
In all the years I have been here I never managed to work out how to post pictures 😚 View attachment 984410
Not sure if it can be bought but the lower half of mine is broke and I'm replacing it. Don't mind removing it and sending it to you to try and replace the fin on your grille.Does anyone know if this part of grille can be bought somewhere??
It's for the 2014 upgraded one.
Can i ask where you got both from? And how easy was it to install?I fitted a number plate light reverse camera and hooked it up to a rear view mirror with auto dimming with 4.5 screen. The auto dimmer is far better than factory fitted one. All cables clearly hidden, it looks stock.
Both from Aliexpress. The number light was easy to install but to make life easy I drilled a 12mm hole to feed eads into the boot. The mirror was tricky. I had to adapt the mount (ordered fiat one) which it came with. I have to cut the end off at the mount and create a tread to mount it onto the existing using with seatbelt and rain sensor area. I just didn't fancy a clip on one and wanted it to look as stock as possible. To remove the old mirror I had to cut the wires leading into it. The mirror is powered into the fuse box near steering wheel using a fuse doubler. I connected it to a 5amp fuse which was an accessory which powered on with ignition, the camera takes power from the reverse light. Its really good but I did it in in 3 stages. I will try to take some photos for you.Can i ask where you got both from? And how easy was it to install?
