21 - 40 of 4633 Posts
Fingers crossed this time Fred. Just thinks its nice to share what we do to our pride and joy's.:)
Well had a visit from Dent wizard and had a few body gremlins removed.. She is absolutely spotless again.. He even noticed a small dent on the bonnet and removed it. :cool:
Also had a call from Gazella racing about my alu strutbrace which should be with me shortly. Nice chap also spoke about suspension setups.:)
And last but not least went to Platinum alloy wheel solutions to discuss the refurbishment of my clover 18's. They did an amazing job on the wheels of my last show car. Have decided on shade and colour now and will be adding a little subtle personal touch.:thumbs:
Damien.
Lets hope so as it was an idea floating around in my mind for a while. So good to see its come to fruition with someone else.
There have been a lot of complaints about Gazella about people not getting there goods and being ripped off. Are you ok with them ?
Discussion Starter #22
I didn't know this about Gazella Fred? Every time i have spoken to them, they seem decent enough. I am confident my order will pull through. Will keep you posted.:thumbs:
Damien.
Damien.
Just be careful then. Have you paid them money yet ? There have been numerous warnings on all Alfa and Fiat websites around the world to stay away.
Have a look at this thread as one example :
http://www.alfaowner.com/Forum/general-alfa-discussion/298749-urgent-gazzella-racing-11.html
I clear coated that steering wheel surround later yesterday and gave the 147 a service. It didn't come with any history at all, so I have no idea if it ever was serviced or when that was, so it was in need of it. Feels beautiful and smooth now it's been done too. All eight plugs, air filter, oil filter and oil done. Next job, belts.
how are you doing these... would love a few exterior items done... what sort of cost is involved please
It is done by a process know as Hydrographics. It is a fairly easy process to do - but a much, much harder process to get right. It is often referred to as hydro-dipping or dipping a part.
Essentially what happens is you pick a hydrographics film that has a pattern on which you wish to apply to an object. In my case the film was a carbon fibre pattern. The film is black and clear - as you can see on my hand below - so the base colour changes what colour carbon fibre you have. The sky is the limit for that, it all depends what colour coat paint you pick. I've used a graphite grey (Ford colour actually) to give a realistic look.
Then what happens you float the film on top of a tank of water (you need to lick your fingers and pinch a corner of the film, the sticky side goes face down in the water, as this is the side you need to hydrate). This hydrates the film. The water temp has to be very precise though, around 33 degrees depending upon the film.
After you let the film soak on the water for about a minute you spray it with an activator spray which activates the pva glue in the film - if you over activate a film it will ruin it, if you under activate a film it won't work - so takes some practice.
Then after about 30 seconds of having activated the film the water surface will look like glass with the film floating on top of it, so you very slowly push your chosen object down through the surface of the water and the pattern film sticks to your object.
You swirl the piece around in the water and remove any excess film then go and rinse the part under warm water to remove all the glue - you can feel it all slimy on the part and it goes smooth and dry as it washes away.
Then once dry you can clear coat it.
Take a look at youtube - there is loads of vids on it and if you are wanting some bits done I have a mate of mine that does it pro if you want I can refer you to him.
Discussion Starter #25
ordered a can of Rhino additive after reading threads on this forum. Does it count as doing something? :)
Now i am very concerned..:( Goods are paid for, awaiting delivery.
Damien.
How much was it you gave them? If I paid by credit card or Paypal or something like that I would cancel my payment immediately if you can, see what your credit card company says about a refund.
Otherwise you can hope for the best. He seems to deliver to some people and others not to others at all. So your guess is as good as mine
I bought my 156 new in 2000 and it was my daily runner for 7 years and since then its done about 4 or 5k, less than 2k in the last 4 years. Ive always fancied doing up an old car wheeler dealers style then my mate suggested that I should try with my own old car rather than looking for something else.
I had the clutch replaced about 2000 miles ago and the timing belts done at 69k last year, about 800 miles ago so why not?
Its an Alfa red/orange/pink colour, veloce/sport pack 1 import from Ireland. The plan was to bring it back to showroom condition, fix every little glitch that Ive let slide for years and then actually use the bloody thing.
Not quite today but over the last 10 days in no particular order....
Cleaned key
Replaced rubber in key
Replaced battery in key
Alarm still wont work
Tried to fix alarm (battery corroded inside ruined part of the pcb, awaiting breaker part)
Ordered new key ring
Tried to fix heater blower (see other thread, obsolete part, need to do a heath robinson fix)
Better check the fan for leaves and main dealer screwdriver or spanner or something.
Fixed manifold heat shield rattle with old portable barbeque
Replaced front badge (bottled out of satin blacking the chrome)
Awaiting rear badge and the joys that will bring.
Gta mod on the headlights
Swore at bumper a lot (pop rivet one side, torx bolt in the same place the other side)
Bent wing as a result of above, hammered and bent wing back so it almost fits
Realised that showroom condition is wish list rather than must have...
New passenger wing mirror
Painted all calipers red
Realised that didnt need to replace all discs and brakes that have been sitting here for a year
Realised I dont have the energy left to replace both lower wishbones and driver upper wishbone that have been sitting here for a year
Sanded down and coated all rust in both front wheel arches
Realised I need to replace the front bumper support struts on each side.
Realised I need to put large sticking plasters on both arms after reaching in to remove bumper torx bolts on each side and finding out about rusted support struts above the hard way.
Realised that wish list showroom condition isnt going to be possible on a 14 year old car without complete respray, infinite time and patience.
Drove to motor factors then dealers then home after realising that just taking the spring out of the washer Y piece would be enough to get me through MOT
4 new tyres and tyre slicked them.
New wiper blades
APC'd entire car inside, outside.
Got car up on lift to look at underside rust to realise I dont have the energy left to anti rust it and then waxoyl that. That job has been waiting 2 years, another month or two wont hurt. Instructions say to ideally do in temperatures above 20C. I live in Northern Ireland, thats approximately 2 days a year.
Vacuumed, apc'd cleaned, scrubbed, wet vac'd all carpets, seats etc.
Bought and fitted new custom mats
Autoglym show shined everything inside
Leather treated gear knob and worn steering wheel.
Fixed passenger visor light
fixed broken drivers door window switch.
Thought about doing led mood lighting 2 leds in top and 2 strips of leds in footwells. Decided to add it to the list
Clay bar'd entire car
Touched up every single tiny wee spot, stone chip including using toothpick for the very small parts
Autoglym super resin polished the whole car which included removing the touch ups above and replacing the newly fresh red paint with tiny white spots of polish hence making most of it worthless.
Realised I should have just paid someone to machine polish it instead of doing this all by hand.
Turned the low spoiler from orange to red-pink. Matt black is the last option....
Realised that looking like showroom from 50 metres is the look I am going for.
Autoglym extra gloss protection the entire car x2
Ioncoat naviwaxed the entire car x2 (all of the above including alloys as well)
Cleaned all black and plastic bits with ipa and then c4'd the lot of it. Huge improvement in the baffle bit under the windscreen wipers
No real improvement on the number plate holder
Took hot air gun to the number plate holder
Some improvement to the number plate holder
Melted the number plate holder
New pressed aluminium numberplates on order
Thought about replacing the handbrake cables that have been sitting for the last 2 years, thought about leaving them for a while.
Oil and oil filter change
Changed the coolant
Attempted to change the air filter, swore a lot, thought a bit, brought out hammer, covered new hole with gaffer tape, brought out blowtorch, replaced burnt wiring as a result of blowtorch shenanigans, swore a hell of a lot more, broke off air filter cover, replaced air filter and then screwed air filter cover back on with some old curtain brackets and self tappers. That f**King thing isnt going to move again.
Thought Id better put an extra bit of silicon sealant around the new headlight mod just to be sure to be sure.
put silicon sealant in rear window gap at top... ...does this mean I have to check for rust in the rear footwell as well? probably
glued sideskirts back on, been hanging off for 4 years since I got the clutch changed and the garage decided to jack the car up via the skirts. Realised the next day after the tiger seal had gone off that Id missed a bit. Swore a lot and realised tiger seal is really hard to get off. Reapplied tiger seal and broken skirt section.
Engine degreased, washed and dressed with show shine.
Broken off battery cover thing stuck back on.
Fitted chrome look bit of bling to rear exhaust pipe to cover the dent in the pipe reversing into a rock whilst arguing with passenger.
Passed MOT.
Its not quite there but its very close, just the alarm to sort out, the internal heater fan and then the hanging down passenger sound baffle trim, replace the old shabby number plates, mood lighting and then the underside anti rust and waxoyl at some point. The underside is in very good nick so its not an immediate priority and the replacement front wishbones can wait until the scars heal and I can put a sentence together without 'f**king car' being part of it.
Took it out for a spin in the sunshine yesterday and how I missed driving that thing (berlingo multispace and transit campervan are the other modes of transport).
When I finish up all the wee niggles and the sun comes out again, I'll do a photoshoot with it and post up the results.
Away for a lie down now.
Joe
Heh, that made I larf.
Pub
I replaced a dead coil pack, unfortunately for me it was cylinder 1 rear bank took me about 1.15
Also replaced the thermostat as she was taking a long time to warm up, an day time temperature yesterday didn't get past 5 deg celcious, and minus 3 overnight,
R
So today in my little 147, I replaced the rear wiper motor so that's all working. replaced the cracked blower unit on top of the dash and tried to fit the Connect+ satnag stereo I bought from a breakers for £20. Problem is I cannot for the life of me get it to change the language from Italian despite hours of googleness so took it back out and put the original back in!
Joefox you have a future in stand up comedy mate! :)
Sounds like you will get there, it's just time and perseverance.
And money.
And spanner rash.
And blood.
Tears.
Auto trader app for looking for a cheap runaround when it REALLY hacks you off.
More money.
Eye wash for those hilarious "rust in eyes" moments. They're funny.
And love.
fixed:-
rear wiper motor,
annoying number plate light that went off and beeped over every little bump,
constantly buzzing headlight adjuster,
windscreen washer jets that sprayed everything but the windscreen,
and topped up coolant,
stupid bella.
Discussion Starter #34
Thanks Fred
Lets say enough for an alu strut brace.. All paid up. Left a message as was getting a little concerned, and they got straight back to me saying my order should be with me any day now. Will give them a fair chance. Fingers crossed.
Damien.
Thanks Fred
Damien.
Oh well a strut brace is not too bad. Usual stories are : I paid thousands $ and still waiting 8 months later for my parts and they never get back to me.
got my car back - aircon is blowing cold :D
filled full tank with triple dose of Rhino (first treatment)
Fixed sticking bonnet catch...which I only found out today, it was ok the last time I was under there. The bit that holds the bonnet closed was fine, it was the red lever that was almost seized.
Undersealed the floorpan and sills.
All the best
Pub
Discussion Starter #38 (Edited)
All the best
Pub
Have to under seal my clover soon. What product did you choose to use Pub? :)
Today i managed to win a genuine alfa ipod kit for 12.50 delivered. Fingers crossed it works well. And will allow me to finally play my ipod in my car. After all the grief with the "Pooh and me" system.
Also realised today the rear GT boot badge design and script is the same design as the early junior badges from vintage Alfa's. Nice little detail.:)
Damien.
Discussion Starter #40
Today I fitted a new head unit PIONEER FH-700BT. Sounds great with the BOSE speakers.
Nice rickco.. Can you still use the bluetooth phone facility on blue and me?
Damien.
