Fitted clear side indicators instead of orange ones on the Spider and gave it a thorough wash and polish.
Did you put new orange bulbs in though?Fitted clear side indicators instead of orange ones on the Spider and gave it a thorough wash and polish.
Yes, the clear indicators came with new bulbs which went in.Did you put new orange bulbs in though?
They do look good on silver... Think I will do my Spider too. Is it a five minute job? 🍀Fitted clear side indicators instead of orange ones on the Spider and gave it a thorough wash and polish.
Yeah very quick. I did it to mine to.They do look good on silver... Think I will do my Spider too. Is it a five minute job?![]()
It is a 5 minute job provided you are very careful not to let the wires and bulb holder disappear into the void behind the wing. The driver’s side seems worse than the passenger side with very little slack. A clothes peg is quite handy to ‘hold’ the wires for you and stop them from disappearing into the car and saving you from a world of hurt.They do look good on silver... Think I will do my Spider too. Is it a five minute job? 🍀
Great, what's the technique? 🍀Yeah very quick. I did it to mine to.
Sent from my SM-G950F using Tapatalk
Great, I will go in armed with clothes peg🍀It is a 5 minute job provided you are very careful not to let the wires and bulb holder disappear into the void behind the wing. The driver’s side seems worse than the passenger side with very little slack. A clothes peg is quite handy to ‘hold’ the wires for you and stop them from disappearing into the car and saving you from a world of hurt.
They actually just pull out, then when you see the clip press it in with a screw driver to release. Mind the cables, that clothes pwg idea is a good one.Great, what's the technique?![]()
Great, thanks 🍀There’s a guide here on fitting them. The bulb holder is a twist and pull bayonet fitting.
How to Guide- Clear indicators for GTV/Spider + pics
This is a guide to change the orange indicators to clear indicators for a GTV/Spider. 1) Firstly push the indicator towards the front of the car. This will squash the metal clip shown in the pic below 2) Pull straight out If that doesnt work use a flat head screwdriver and wedge it...www.alfaowner.com
After the Christmas/NY interruptions, finally scooter'd the GTV. Lambretta sproings fitted. If I am brave, I'll go and bleed the whole system tomorrow or so. Woooo!Rather better than what FCA tried to rush me when I enquired. So I spent all of 10 minutes searching Teh Interwebs and found some for €1.29 each. Most satisfactoryfrom "Lambretta Parts" - www.lambretta-teile.de ...
Thanks tho, Nelly
That’s a job I need to get the confidence to have a go at now I’ve got the GTV and Spider. Is it difficult?Bought £200 worth of belts, tensioners water pump, thermostat, gasket etc for the Twin Spark. Best guess of when belts were done is 2016 so better safe than sorry, considering it's a day's job
It's not hugely difficult, but it is important to do it carefully, and follow the correct proceedure. This includes using a dial guage to get to TDC, using the cam locks, and also slackening the pulleys on the cams to get the alignment spot on. Once you have the tools and a guide it is much less daunting.That’s a job I need to get the confidence to have a go at now I’ve got the GTV and Spider. Is it difficult?
Thanks... I really should invest in the tools and have a go myself. Post Covid next time I’m due getting the belts done, I’ll probably ask my local indy if I can watch while they do it.It's not hugely difficult, but it is important to do it carefully, and follow the correct proceedure. This includes using a dial guage to get to TDC, using the cam locks, and also slackening the pulleys on the cams to get the alignment spot on. Once you have the tools and a guide it is much less daunting.
Interesting that you only do the inlet, that one is certainly easier than trying to do the exhaust. I'll try that this time. Also the timing cover bolts are the worst thing about the entire job. Luckily I have a spare cover to hold the bolts nowThere are a few guides on YouTube showing how it is done. You do need the correct cam locks and the dial gauge. Whilst I do slacken the inlet camshaft I’ve never had to do the same for the exhaust camshaft, it has always turned out spot on. I do the tensioner right up and turn the engine over two complete revolutions and put the cam locks back on to check. Of course the tensioner is then set to the right position. Always exactly right but I suppose some have had to slacken it. You also need the Ribe sockets but Torx may be able to do it, I bought the correct tools because I like buying equipment. I already had the dial gauge as we used to set up the ignition timing on the racing two-strokes a certain movement before TDC rather than in degrees.
One thing I made was an outline of the cam belt covers in corriflute with the holes in the right places for bolts. I didn’t have it for the first time and then spent ages getting the correct length bolts in the correct places; they are of different lengths and in some cases very close to each other. I learnt from that.
