I visited a few websites of Alfa 155 owners recently, and noticed most have made modifications to their cars, ranging from tyresize to chiptuning, etc...
I've compiled a little list of changes I made on my '92 2.0 8v
- EBC gold range groove brakepads combined with Sparco T-51 brakepads, all around. The pads it had heated too fast and never did have the bite I wanted. This combo works great.
- K&N 57i induction kit. I stilml have to modify this a bit, I don't like the location and small size of the filter.
- FK Königsport suspension. Front + rear adjustable in height and hardness... Also a good combo for handling, but detrimental for comfort as was to be expected.
- Supersprint exhaust excluding the manifold (original still) and the last damper (Remus). I made these changes in steps, starting with the cat replacement. Gained 6 HP on the testbank.
- I had a custom ECU made, with the rev limiter 300 RPM higher, and now 164.5 DIN HP at 6200 RPM and 213.8 Nm at 5200 RPM on the testbank, measured on the wheels and calculated back. Anyone else got any figures about his car? Mighty curious....
- A spoiler on the trunk, to keep the back end in line at high speed. It's the standard spoiler from a Ford Escort RS2000 ('92-'94)
- 16" rims and Goodyear Eagle NCT5 205/50 R16 tires. They are actually too big for the car, so next time I'll get 205/40 in front, 195/45 in the back.
What I need to change:
- The steering rack. I want a more direct version. 2.5 sounds good to me. Anyone know a retailer who can sell me this? The one I got has a knick in it, MOT will find out sooner or later...
- The bushes on the wishbones... Powerflex ofcourse.
- Would like to get the flow improved inside the engine as well, together with replacing all the bushes and bearings.
Cuore_sportivo_155, back to work...
Ok here is/was my Silverstone spec:
Kahn RSR wheels
clear side repeaters
newer 16v chrome recessed grill
FSE fuel pressure regulator
Squadra and Autodelta chips (at different times)
Green Cotton Induction Kit
G&M uprated suspension
Brembo 10 groove front discs with Red Dot pads
Stainless Steel braided brake hoses
Chrome gear nob, surround and lever
Alluminium flooring (the carpet was torn)
Momo pedals
Momo Strut brace
Powerflow SS exhaust
Decat
Modified AFM (took a bit of time to get it right !!!)
Car pushed 144.4 bhp on the rollers. Standard is 129bhp for the 1.8litre 8v.
Ok, looked them up on the net... Do you think it'll help me reduce the flat spot in the torque between 3100 and 3800 RPM, and the massive fall after 5000 RPM?
Here's a picture of the printout they made when I got my new chip. february 3, 2004. It could definitely be a lack of fuel, surely the drop off after 5000 RPM. Any thoughts anyone?
Cuore_sportivo_155
EDIT: Blue = torque, Red = power on the wheels, Yellow = engine power, Green = dissipate power. Would be best to know...
here are my mods to my 2.0 16v super.
-custom leather interior ( the middle portion of the seats i changed it to black leather.
-17"x7 oz superleggera rims and 215/40 tires( nice and light weight rims)
- 2 10" kicker subwoofers
- indash dvd player
- splitfire spark plugs
- squadra performance chip
- Stark s.r.l. full suspension kit (lowered by 40mm)
- full supersprint exhaust (headers to rear silencer)
- carbon fiber look door handles (only stickers)
- 2 pairs of HID xenon bulbs (foglights and headlights)
- custom made chrome grilles
- ebc green stuff brakes
- defi link gauges (fuel and oil pressure)
- steel braided brake hose
Here's what I got on my 155 1.8 TS 16V
Engine bay
- K&N cone filter with aluminium pipe, cold air pipe and home made heat
shield
- Colombo & Bariani 280/272 medium street cams
- Castelli performance chip
- FSE fuel pressure regulator
- 155 2.0 TS 16V radiator
Exhaust
- exhaust enlarged to 2.3" decatted
- Supersprint rear muffler
Suspension, Brakes & Wheels
- Eibach springs all round with a FIAT Coupe 20VT Eibach front pair
(lower stance and stiffer)
- Koni yellow shockers
- Goodrigde steel braided hoses
- 284mm brake conversion from the 155 2.0 TS 16V
- Jurid normal compound brake pads meant for 164 Turbo
- FIAT Coupe 20VT 7"x16" Speedline alloys sprayed dark grey
- 205/50-16 Goodyear Eagle F1 GS-D3 (supposed to be 205/45-16 but
using oversize for cosmetic reasons, closer to wheelarches) :D
ICE
- Clarion HU with 6 CD changer
- Mixed set of speakers Alpine & Rockford Fosgate.
- 2 units 12" Rockford Fosgate subs
- Helix HXA40X MKII 4 ch amp
- Helix HXA20X MKII 2 ch amp
Interior Stuff
- HKS Type 1 Turbo Timer (use it to show voltage & rpm with warning
at selectable rpm, supposed to have speed function with 0-100kph
0-200kph, 0-300kph timing, quarter mile and lots more, but couldn't
get the speed related functions to work with our cars, speed
reading way off)
- Watchers 2-way car alarm with a 1000m (3000ft) transmitting range
- OMP aluminium pedals
Exterior & Cosmetics
- Philips 6000K Ultinon HID H1 kit
- White side repeaters
- Silverstone rear spoiler
- Silverstone front lip (not fitted, too low to even climb my home car
porch)
- Hella FF50 driving lights, replaced stock foglights
- DIY single wiper conversion, parked BTCC '94 style
- 2 sets of Stebel Nautilus air horns :D
Future upgrade (if I got enuff cash) :lol:
- entire ICE setup, now running quite a budget setup
- top strut braces
- anti-roll bars
- engine work - port & polish, increase displacement
- Brembo front calipers & 305mm discs
- maybe a low pressure turbo? (Wanna eat the Bimmers) :D
- lots more......
Might have missed out a few things, as these mods were done in the course of 8 years.
Cuore_sportivo_155
your power curves look fine to me. they are very similair to the graphs on www.squadra-tuning.com
the FSE valve would help the flat spot. it did on the Silverstone.
was the car run to the rev limiter when on the dyno ??? if the tester lifted off early that'd give the sharp drop at 6000rpm.
My Silverstone reached max power at 6500rpm and didn't drop off as quick as you graph. The FSE wouldn't cure that if it is a problem. if the car was being starved of fuel up there, you'd probably see a flat curve as the car would stay about the same power I would have thought.
