I have removed the head from my156 2TS, cleaned everything possible and my next task is to remove all valves.
My question is should I look at replacing anything else other than cam belt, timing belt etc now that the head is off?
thermostat, temp sender, crank sensor, re-furb starter....
M
Ah dont fix whats not broke as no matter what you replace something else will brake as the only sensor I would change is the crank and that is only cause it is the only one that will fail and its cost is so small...
