1 - 20 of 22 Posts
I have been reading through some of the threads and as with all technical discussions it has its own set of acronyms and abbreviations.
Can any one tell me the meaning of the following and what they do:
MAR
MAF
FES
EGR (valve)
ECU
OBD2 cable and where to buy it.
FiatECUscan or Alfadiag and where can they be down loaded
L
MAR = 1st position of the key
MAF = Mass Air Flow meter
FES = FiatEcuScan
EGR (valve) = Eco Gas Re-cycle
ECU = Electronic Control Unit
OBD2 cable and where to buy it. = try Ebay
FiatECUscan or Alfadiag and where can they be down loaded = try googling the names
"MAR" is the first position of the ignition key after off (there is: Park, Off, MAR, Start)
"MAF" = Mass Air Flow sensor.
"FES" = FiatECUScan
"EGR" = Exhaust Gas Recirculation
"ECU" = ECU...!
FiatECUScan & AlfaDiag can only be downloaded from their respective websites.
Plenty of cables on eBay.
Interesting thread.
Anybody knw what [LT] means - ie: 2.0 JTS [LT]
Depends where you are looking.
In the model descriptions it can mean Leather, ie:
2.0JTS Veloce - to mean a normal Veloce.
2.0JTS Veloce (LT) - to mean a Veloce with Leather.
L
ESP = Electronic Stability Program
BAS = Brake Assist System?
PDK = ???????
SRI = Single Rail Injection?
LSD = Limited Slip Differential
ACU = Air Control Unit?
L
JTD means its a Jetronic Turbo Diesel
with a small m it means Multi-Jet [ fires 3 or 4 times per compression stroke ]
talking of acronyms.. any body know if i can data log and play around with the afr using alfadiag? or do i need to look for a seperate ecu spy app? :p (being lazy)
SRI. service reminder indicator. ( think of your MY99 airbag )
ACU airbag control unit , the little box with a spring loaded metal ball which makes contact after an impact of + 2G and signals the ECU to fire the squibs in the airbags
PDK is the double plate clutch ( Porsche )
just got arrested by the AAAA ! Lifted me from my cozy warm bed.....b*stards
I paid £12 for a ELM Bluetooth connector. FiatECUScan has connected OK. I have only looked at engine parameters, not sure it will do anything else. Will at some point have another look.
1 - 20 of 22 Posts
