So my drivers electric window has become very slow is it a common fault? What kind of job is it to do?
Not known it as a common issue - have you tried some silicon lube in the window channels?
Usually it's a matter of needing lubrication....
Preferably silicone oil or PTFE, in the guides and possibly the gears etc.
It is about corrosion on the metal cable that pull the window. If you can manage to reach that part, it is an easy job. Addition, you can use wd40 inside the window channel to make it faster. Not an issue of the electric motor.
