Hi, just wondering if anyone on this site is familiar with waterless coolants and whether it can be used In the TS engine?
I have no experience, but why would you want to use a waterless coolant in a TS engine? I've got mine running 5 year longlife mixed with deionised water (water 2 : 1 coolant).
If you search the forum you'll find that it has been asked many times over the years.... several times this month alone!
  • Like
Reactions: armoore
The long and the short of it is I wouldn't bother; the coolant is expensive and you also need to flush the system and prep it using proprietary products. Also if you get stranded you cant top up the system with water or normal coolant. If you have overheating problems you should focus instead on identifying the problem eg silted/leaking radiator, collapsed hoses, water pump, head gasket, fan switch, thermostat
