1 - 2 of 2 Posts
hi all
driving my 147 around on another fine spring day! (rain all day)
noticed a curious liquid sound when turning sharply, like water slooshing round a container, i wouldnt worry but it sounds like a good couple of litres!
also the rear wiper is stuck at 2/3rds stroke?
any thoughts!
Well, look at it from a logical point of view... It can only realistically be three things, washer fluid bottle, coolant header tank or fuel tank. If neither are leaking, then you have nothing to worry about then.
Logic again plays a part in the wipers.... remove the arm and refit where it should be and try it... check the fuse! If that isn't it then try cleaning the wiper switch with contact cleaner, next try the motor and do the same to the contacts...If that doesn't work, then its the motor
Coincidently, if you require a new motor, don't bother with an alfa one second hand, they are far too expensive... Go for a Fiat Marea! same part number, same motor, same assembly and same length... Just £15.00 cheaper at the breakers yards... Oh and far more common!
1 - 2 of 2 Posts
