1 - 9 of 9 Posts
Hi guys,
Can anyone recommend a good product to remove water stains from the paint work (white giulietta) ?
Also, I have a black roof and may have been a little vigorous trying to polish out the water stains and now have wierd swirls marks. Anything you can recommend?
P
Not sure on the water stains but apparently scratch X is very good for swirls etc....... :D
I wouldn't go down the scratch-x route, it's very filler heavy and doesn't remove the swirls. Also hard work for what it is. If you are going to do it by hand the best polish is Gtechniq P1, but it can get a bit dusty.
Water spots can be cured by most quick detail sprays, just depends on your preferred manufacturer, if you don't have one, my I recommend Auto Finesse Finale QD, which is my go to QD. In fact, I've just finished my 159 today and have machine polished with P1, then used an AF lsp and wiped down with Finale. The gloss levels are off the scale and my car is silver :wow:
Sounds like you're a pro! I'm planning on doing it by hand so ill give your recommendation a go. Where do I get it? I take it I won't find it in halfords!
Thanks for educating me Sean :D
Don't mention it, other Meguiars stuff is good, but scratch x is only designed for filling the marks and is hard work, I used it once for under door handles and stuff I couldn't reach by machine, but there are better products now IMO
I do a lot of detailing, and it is a big hobby of mine and I look after a few cars for people. I like trying new products all the time, but there's one range I love and keep coming back to and that is Auto Finesse, I met them at a motor show and spent a fortune with them and kept in touch and bought more off them since.
P1 polish from Getchniq is great stuff for using by hand and you can get it direct from Getchniq, but I tend to get all my gear from clean your car.co.uk because their service and product range is spot on
P1 is here Gtechniq P1 - Nano Composite polish - Clean Your Car
Finale is here Auto Finesse Finale Quick Detailer - Clean Your Car
There are cheaper hand polishes as I said, but this has great cut by hand and won't make nasty holograms when you use it.
Finale is easily the best smelling QD (All AF products smell awesome!) and smells of strawberrys :D A little goes a long way too :thumbs:
Beads well too
P1 polish is good but whatever polish you choose it is also worth buying a 'german' foam pad. These are perfect for hand polishing and consist of a soft and hard side so you can do the cutting bit with the hard side and refine the paint with the soft side. I would suggest starting with the soft side first
P
I only tried one Auto finesse product and that was the tyre gloss, it doesnt seem to last long both durability and uses per bottle. Just switched to Dodo Juice Tyre Wax.............. WOW awesome stuff.
With that said, maybe I should just give AF a chance and try other products.
The big black hole of detailing.
Yeah both AF tyre shines are poor on durability and I don't like lather shampoo, I prefer DJ BTBM because we all love suds :p
Otherwise I love the range :D
1 - 9 of 9 Posts
