1 - 9 of 9 Posts
I want to change the timing belt and water pump on my 156 jtd 8v. the water pump sits behind the camshaft pulley...how do i hold the camshaft pulley to remove the centre bolt? what is its torque wrench setting when i refit it?
also is there a special tool for taking off the tension from the cam belt tensioner...what else could be used as i haven't this.
many thanks, krispy
many thanks, krispy
dont need to remove cam belt pulley as far as im aware
you need new tensioner and idler and you dont need a spacial tool to do it neither
I cant remove the water pump as the crank pulley is in the way, so cam locks needed. Does anybody have a set I can borrow in the Kent area.
Cheer
Have you looked the guide/how-to on AlfaWorkshop's web site??
L
there are TOOLS available to lock the TWO cams in position....... therefore you can remove the pulley
8V and 16V have different pump and belt arrangements.
I could not remove my 8V water pump without removing the pulley. My 16V car did not require the pulley removing to change the pump.
On the 8V car I made up a cranked rod with two pins through it to hold the pulley while I removed / replaced the locating bolt. This worked in a similar way to the tool shown in the electronic elearn procedure. I guess you could lock the cam and fuel pump pulleys together to hold the cam pulley. They are not that close together though.
To my knowledge JTD's all have a single driven pulley for the cam(s). The 16V twin camshafts are timed by means of gears at the flywheel side of the engine.
I would want to use a torque wrench to secure the timing pulley. You don't want that coming loose!
That's my experience anyway. Hope that helps.
Old Bo
You are quite right, the cam pulley does need to come off to get at the water pump bolts on the 8 valve engine.
When I did mine I loosened the cam pulley bolt with the old belt fitted, changed the pump and then refitted the old belt to hold it whilst I torqued the cam pulley bolt so I didnt damage the new belt and then fitted the new belt.
The tightening torque listed in Auto data for the cam pulley bolt is 102-126Nm
1 - 9 of 9 Posts
