After a few bouts of heavy rainfall we've been having recently, I've been noticing water pooling in my side skirts - so when I drive away I leave two trails of water for a few hundred yards....
Can tell how it getting in, or how its meant to drain out?
Any ideas?
Bit strange never heard of that before, what car is it on? normally if the skirt is not attched properly then that could cause it and i think that it should drain out the bottom? should not be anything to worry about that skirts are plastic, so they wont rot and they body is galvansied so no problems there
Its on the 147GTA.
I've not had an issue with it previously, so I was guessing at a blocked drainhole, but I'll be buggered if I can find it!
yes mine does this on one side resulting in a sloshing noise when pulling away and and braking, ive no idea how to sort it out either!
You could drill a hole in the bottom of the sideskirt so the water can drain out..
