1 - 2 of 2 Posts
Stelvio 2.2JTD 180 2017
Hi,I noticed that the water from the wipers infiltrates into the right part of the engine compartment. when we open the hood, we see that on the left there is a reservoir that collects the water from the wipers to drain it elsewhere. on the other hand, this reservoir does not exist in the right part and suddenly I notice that the electrical harnesses and an electronic box are often wet with water when it rains or when I use the wipers. is this normal? have you noticed this problem?
934290
934291
Hi mistermido,
I've attached a doc relating to recalls about water intrusion etc.. further down it references how to fix it if it has'nt already been done on a recall .. I'm not 100% sure if this applies to UK models as I lifted it from a source on the US Stelvio Forum .. I'd also check whether your vehicle has had the recall work done.. Also I don't know if it's relative to your problem but you might be able to assess your issue a bit better after reviewing the doc.. I think this particular doc is aimed at preventing water getting down inside the cabin and compromising the BCM unit which I think is located inside the passenger footwell under that plate..
1 - 2 of 2 Posts
