1 - 10 of 10 Posts
I collected my brand new Mito in December 2009, from day one my brakes have been grinding but I assumed they just needed bedding in so i gave it a few months. I rang the garage in February to advice them of this problem. I had the car seen in April for this problem and others and was told that for the garage to even look at the brakes to see if there was a problem would cost me £90 as it was classed as wear and tear!!!!
I advised them that this had been happening since I have had the car but they said that even if I had bought the car back the next day it would still be wear and tear!
I am now worried that if anything major happens that I will get the same response 'wear and tear'! It doesnt fill me with much confidence in the warranty!
other people have had their brakes done under warranty as its a known fault on the mito...get in touch with aruk and get them to sort it for you, use the freephone number you have for the AA and use option 3....:)
Try another dealer, no saying it has to go back to where it came from for work...
Sent from my HTC Legend using Tapatalk
I thought someone actually posted the reference code for the brake issue before...? So it is a known issue to be fixed under warranty...
Brera 2.0 JTDm
The number posted was specific to the MiTo 155TB which has different brakes to the other no MA MiTo's so not sure if there is a known issue with the others. A call to ARUK customer line should be able to answer it for you
If it's any consolation every Subaru I have ever had had squealing brakes from new, and for that matter every Peugeot... I just copperslipped the backs of the pads myself.. twenty minute job. You say it's binding though....
1 - 10 of 10 Posts
