not sure if they are the same size, but the side badges are available...just measure your wing emblem and the space for the emblem on the radio blank plateI’ve got the plate, but not the badge, are they available?
I’m near Winchester in Hampshire, I managed to get an Alfa 33 tank which was used for many of the conversions, mine currently has what i think is a Chinese tank made from Aluminum.I can probably help with some bits. I think I saw elsewhere you are after an expansion tank. If your car is LHD then I have a tank available. I'm near Harlow, Essex, where are you?
Couldn’t count how many times I’ve been there in the alfa!! Lived there for years.I’m near Winchester in Hampshire
Have you done some simple tests? Pump the brake pedal several times then hold it down… then start the car…. Does pedal go down a little? If yes that’s a good signI suspect the servo will need replacement as the brakes work but the pedal feel is awful.
