Wanted, Alfa 105 series pre - 72 steering column shroud (both halves), for long column.
Needs to be decent condition please, cash waiting.
Many thanks
Steve
I am also after a shroud but for a 72 onwards 2000gtv (was unaware of difference) even just the top half, as I have a bottom...
Bump, anyone have one ?
Many thanks
Steve
Steve, do you know if these are model specific? Or do cowls from spiders & different years etc fit?
I haven't got back to you anout my spare because I found that mine is held together with black electrician tape, I need to take off at sme point and compare with spare as that seems to still have some of its captive nuts.
Hi Sean - if you make yourself a better one at some point out of the two you have, I would still be interested in your rejects - I've half a cowl, can't remember if it is top or bottom and its in 3 pieces... still fixable though and if I'm fixing one half, I might as well fix two :thumbup:
They're obviously fragile, being thin and now brittle plastic - was thinking of using a combination of fibreglass and JB Weld to reinforce from inside, followed by refinishing the outside with left over products from my dashboard refurb.
I'm not in a rush given the slow progress on my project! As and when...
Mine is not the "flat dash" type that Alex linked to above, it has the ignition switch on the column, so I'm looking for a reasonable, long column, up to 72 one.
Steve
