Administrator
Not a very common alloy on the 159 unfortunately, standard on the early ti in Ireland & only an option on others AFAIK. I'd say you need to try sourcing one on ebay or across the water if you haven't already done so, might be worth post a thread here also Alfa 159, Brera & 946 Spider - Alfa Romeo Forum
Good luck with the search.
I got this welded after and its holding up. This was a small crack on the inside edge of the wheel, and i felt it wasnt a structural crack, just one that was letting a little air out. You hear a lot of conflicting opinions on the interweb about alloy wheel welding repair, but every cracked alloy wheel is different.
