S
Spacecadet
·Guest
I have been using 90 mm OD. Sqeezed inside the rubber on the MAF just so.Well, lesson learnt. The intake pipework isn't 76mm! The 76mm alloy external diameter pipe is 8mm too small! The resonator pipe measures 84mm external diameter!
Anyone need a 76mm alloy 90 degree bend. Let me know!
Where on earth do you get 84mm outside diameter alloy pipe 90s?
It seems standard sizes are 76mm, 80mm, 90mm and 102mm
Indeed I should, but I think with older cars, the grime and muck is holding it all together. If I clean something, it'll start to leak, or explode, or cost money to fix!Looking good, just need to clean everything else to match!...![]()
Every little helps I guess...Indeed I should, but I think with older cars, the grime and muck is holding it all together. If I clean something, it'll start to leak, or explode, or cost money to fix!
I can't be having with that.
That said, I did fit a new coolant bottle last year, and I wiped the oil up when I filled it up recently and it dribbled, so there are two other clean bits!
Sent from AutoGuide.com Free App
There is very little to tell.That looks nice - you doing a how to guide ?
And links to what you bought ?
Thanks![]()
