I am experiencing vibrations when accelerating harder then usual on 3/4th gear.
Another problem is random grinding/knocking noise probably coming from driver's side. I have recorded the video of this noise. Please watch with speakers full on.
https://www.youtube.com/watch?v=jU5dm-6ohEI - most obvious noise at 0.50 minute
Could this be suspension problem?
m32 Gearbox problem?
Driveshaft maybe?
Anybody experiencing same problem?
Thanks!
knocking probably is suspension related you will need to jack the car up but as for vibration your driveshaft is knackered ,i had the same on 3/4 and it got worst finally making car hell to drive
2017 Guila 2.0 Tbi Lusso spec, 1972 S2 Spider Junior, wife drives 939 Spider, + Abarth 595
Drive shaft joint.
Thanks for the info! Have you replaced the driveshaft?
My mechanic recommended to remove the driveshaft and re-lubricate it. You think that this will help or is it just a waste?
Knocking & Squeaking noise was sorted - ball joint in upper wishbone from driver's side was gone. sorted by replacing the wishbone:
55 pounds labour
135 pounds wishbone
Although the car still vibrates while accelerating on 3-4th gear.
Mechanic checked the driver-shaft and said that it look aright
or does it?
Hello. I have the same problem with the vibration under acceleration (1.9 JTDm 150hp) Just when accelerating from under 2000 and only for a short time. From 1800-2100 rpm. 3,4,5 and 6th gear. If i accelerate from above 2000 it will not vibrate. I replaced clutch, flywheel, CV joints left and right. And today i change the whole right drive shaft. Two weeks ago i changed the driving belt and accessories. I also removed the swirl flaps, DPF and EGR is off. I also changed the engine mount from the gearbox. I still got the vibrations!!!
It's driving me crazy and i really don't know what is there left to change. Someone said it could be the gearbox. :(
