Hi All,
I've recently changed all the belts, tensioners,water pump and variator on my 166. When I pick away or when the engine is under load I can here a vibration from the timing belt area. I suspect the belt tension may be wrong. Can anyone confirm this or suggest what the problem might be. Thanks.
Burt.
Burt.
