hi not getting enough mpg.
any directions to point me in
thanks
thanks
my 09 mito 1.4 non turbo was returning 43 to 48 mpgMore to the point, what mpg are you expecting? Throw official figures out of the window, they're not worth a penny.
59 reg getting 38 mpg my petrol 1.4 could get average 45mpgHow old is it? What kind of mpg do you get?
thats good im getting 38 mpg thought 1.3 jtdm would be nearer 60mpgNot quite a direct comparison but the same engine.
I had a 2013 Fiat 500 diesel, average mpg was around 55mpg if I hoofed it. On a feather foot I managed once to get a tank average of 99.8mpg, that was mainly up and down the M5 to see my daughter with cruise control set at 65mph.
cleaned dpf dpf light went out also added dpf cleaner in fuel mpg up too 41.8 and still rising still got engine check light on fitted new fuel rail sensor as well and fitting crank sensor tomorrow.will up date as i gohi not getting enough mpg.
thanks
tried too but failed to replace my crank sensor today cant find itcleaned dpf dpf light went out also added dpf cleaner in fuel mpg up too 41.8 and still rising still got engine check light on fitted new fuel rail sensor as well and fitting crank sensor tomorrow.will up date as i go
got it up to 52mpg changed fuel rail sensorDoes the 1.3 have a DPF? That might be blocked. Or the EGR might be clogged up, or worn injectors maybe?
was 34mpg got it up to 52mpgHow old is it? What kind of mpg do you get?
