For quite a long time the variator on my 147 TS has rattled for a few seconds after start up, as seems common with older variators. I didn’t think this a significant issue since it quickly quietened and the engine performed well enough, and, accepted wisdom seems to be there are no adverse affects from a noisy variator other than the rattley start up.
However, sometimes the engine would feel a bit ‘off’, more so some times than others. This would usually be after driving for a while or later in the day, and I wasn’t sure might not be a figment of my tiring imagination. The engine would go from feeling fine to just seeming a bit ‘flat’ and lacking ‘enthusiasm’. The next morning it would seem ‘refreshed’, so maybe it was just in my head...? But, later it would again start to feel a bit lacklustre. In the end I decided something seemed to be wrong...
The question crossed my mind; could it be that the variator might possibly be causing an erratic problem, even when it wasn’t being overtly noisy at the time? If so, then why exactly might that be?
So I decided to investigate...
My spare variator (from the spare parts car) was externally rusty, and obviously not useable in such a state (how did it get like that...?). I pulled it apart to see if I might be able understand exactly how it works and what might possibly go wrong with these things.
First impression was that it seemed in excellent internal condition. There are relatively few moving parts, most of the components are hardened (probably) steel operating in a very well lubricated environment, and exposed to only relatively light loadings.
There appears to be very little that could actually fail. The fact that variator ‘repair kits’ consist only of a new spring and plastic thrust washer tends to support this, i.e. that not much goes wrong, and that if it does then the spring and / or plastic thrust washer will most likely be the problem.
Next I dismantled the variator from the road car, and after very careful examination this too appeared in similarly excellent internal condition to the other, as far as I could tell (and not rusty on the outside...). So what was wrong with it, why the diesel like rattling?
But, before I go further into this, the happy ending here is that this variator has been successfully ‘reconditioned’ and is now completely silent, zero diesel like rattle at any time, not even momentary. And, I’m sure the engine is now running more smoothly and performs far better than it previously did.
And the cost, other than my free labour, only $0.00...
The variator components look like this:
End part one...
Regards,
John.
End part one...
Regards,
John.
