Have been checking the valve clearances on my Giulietta. Five out of the 8 valves require shims below 1.50 mm. The range of available shims is 1.50 to 3.50 mm. Some of the existing shims are below 1.5 so I guess they've been machined in the past. The biggest shim fitted is 1.99 mm and the smallest 1.13 mm.
The cylinder head was re-furbished a year ago with the seats re-cut.
Any advice appreciated.
If anyone has any shims lying about they don't need, I would be keen to buy them.
- Are the small shim sizes just a reflection of the valve seats being re-cut?
- Have the valve seats been cut too far?
- What's the thinnest shim size you can safely go to without them becoming weakened (I need one at 1.05 mm)?
