The 147 has quite a vague gear change, it's just not very tight or mechanical feeling. This wouldn't be an issue but its rather difficult to select 2nd and reverse.
2nd you get used to once you know where it is, but sometimes it wont go into reverse at all, or will grind the gears. If I select 1st and then go to reverse it usually engages but there is very little feeling to it...
Suggestions?
Suggestions?
