1 - 16 of 16 Posts
I've brought a obd vag com lead from ebay but I assume it work work because the pins need changing etc.. Can anyone tell me the correct pin layout?
Is it a KKL type? What are you trying to diagnose? - if it's airbag or ABS there will be some 'bridging' required, otherwise it should communicate with the main ECU
Not sure about KKL? Trying to connect to airbag ecu on a p1 & p2 and have the 3 pin adapter lead
Ah I've been getting confused. Basically I have the correct set up but still doesn't work so I'm thinking a break in the cable. Cheap stuff from china :tut:
Well I've even brought Alfa Diag.. It connects to the engine ecu but just will not connect to the airbag ecu no matter what
to connect to the airbag ecu you need to remove the cover from the main connector and solder a joining wire between pins 3 and 7 to be able to communicate with the airbag ECU
TRW and yes.. Tried just about everything to get it to connect even expensive diag equipment and it still wouldn't connect so starting to think something is wrong with the airbag ecu but that wouldn't make sense because it was ok until I just removed the seat :S
saw you again Jake (blw nice gtv!) at the tesco round about at 10ish, did you see pete? (rosso red spider with gtv number plate) he was 3 cars in front of me heading towards the bridge.
have you read theses for p1, for might be best taking to the dealer?
http://www.alfaowner.com/Forum/alfa-gtv-and-916-spider/106067-airbag-light-reset.html
http://www.alfaowner.com/Forum/alfa...44300-3-pin-diagnostic-port-on-p1-spider.html
http://www.alfaowner.com/Forum/alfa-gtv-and-916-spider/135613-help-please-gtv-airbag-light.html
Discussion Starter #14
I didn't notice was still half asleep :lol: went halfords to pick up some axle stands :thumbs:
It might have to be a dealer job :(
1 - 16 of 16 Posts
