1 - 16 of 16 Posts
I've spent a lot of time away this year so I've had my V6 parked up in the garage unfortunately, zero miles this year. I'm back now and want to play, so have put it into a MOT this week. Not too bad, 4 x new Eagle F1s have gone on and emissions will need sorting - but it has sat for a long time (although regularly turned over) so a good run out should hopefully sort. There is also an imbalance across the rear axle, I suppose I could strip the calipers down but I 've been thinking about putting on new rear calipers - does anyone know of any good deals going? Looking for the 6 fin alloy type, part no. 735245678 & 735245679. I see there in Alfashop for £136 each.
Have you tried these people? It would seem they do TRW OE replacements too but you have to call for a price. Budweg would seem to be a good refurbisher,. They are a Danish company. More details about them here.
Great shout, thanks.
Big Redd come highly recommended although i haven’t used them personally. Saw a photo of a pair they refurbished for someone on Facebook recently. I think he said they charged about £190 for a full rebuild including paint in a choice of colours.
Recommendation for BCS here.
Big Redd also do a good job but didnt have the colour choices I wanted.
Thanks all for the recommends, BCS & Big Redd look good. I have no time to do the work myself, so have ordered an alloy set from brakeparts (v6coop's recommend), which the garage can put on later this week, I'll send back the old calipers later to reclaim the surcharge.
+1 for Big Redd. They did a great job on all four calipers for my S4 Spider.
I'm probably going to get my 916 ones done by them too. One of the rears looked as though it is sticking, when I investigated the pads recently.
Its usually the handbrake mech that seizes, its a simple case of taking it off and lubing it all up. Its worth a try before you go shelling out needlessly.
Thanks for the tip, I will investigate that first.
I had a pre-MOT done on my Spider and they picked up on something with the rear brakes. I replaced one of the springs and sprayed the lever bit that the handbrake operates with WD40 and alternated between applying the handbrake, releasing and tapping the lever with a hammer until it operated properly. Probably be a lot quicker to do with a helper.
Thanks for the info. Does the handbrake operate directly on the caliper pistons ?
930437
The handbrake pulls the lever in the direction of arrow A and when released it should get pulled back in the direction of arrow B by the spring. The springs often go AWOL or don’t do their job. A liberal spray of WD40 and moving the lever manually generally gets things working as they should.
Just to update:
MOT PASS - I gave it a quick blast up & down the A14 (Suffolk) to blow out the exhaust - emissions sorted. I fitted some new rear calipers from Brakeparts as per post no.2, thanks V6Coop, great service and calipers as new. Handbrake, as always, is a 16.1% pass!
Just to update:
Glad it worked out Matt. Just out of interest which (re)manufacturer did you get and were they painted?
Discussion Starter #15
I went for the Budweg remanufactured option, the allu alloy version. Very impressed with them - I've done my own caliper refurbs in the past but didn't have the time this year. They were not painted, I'll look at matching the colour to the front calipers in the Spring. The calipers are as new and have made the braking a bit sharper. I fitted new 330mm Brembos and discs as well so the setup is pretty decent now. I use 'Performance Friction Pads', which are very good.
All that said, I think even with all these mods/upgrades it is still a case of 'marginal gains' with the GTV, overall the GTV's brakes aren't brilliant (I've had 4 - 2xTS & 2xV6) and they've all been roughly similar. I've replaced practically all my brake lines on the current car and also had the rear brake compensator off to clean out. When I compare the GTV to a modern standard car, like my wife's horrible Peugeot, the modern car wins hands down, with bog standard brake parts & discs.
I think there should just be more braking power there in the first place, so master cylinder territory I suppose - I've haven't played with that....yet!
Sometimes I never knew how I stopped the gtv in time.... I put it down to witchcraft and wizardry or divine intervention..... Went to GTA 330s and groove and vented discs with ferrodo 2500 pads. They tend to squeel a bit in summer but stop the gtv a lot better.
1 - 16 of 16 Posts
