Hi fellow Alfamaniacs,
Should a 1999 V6 have two cooling fans, or one two-speed fan fitted?
Mine came with a crappy Boston Rad' and weedy kenlowe fan fitted and i want to put it back to OE spec, as it's not cooling properly in this heat.
Seems 2 cables have also been snipped (thick brown and white ones at the front of the loom, above the rad' ) could these be the low or high speed power feed?
I'm guessing the biggest ones are 50A and the slightly thinner gauge ones 30A?
or wot?
Previous owners, eh... :rolleyes:
Some have 1 fan some have two it seems.
However, if you have cut wires, it is certainly possible the car had two at one time and two fuses would also support that.
It doesn't seem to be working too well at the moment, but I'd type my VIN into ePer
eper.fiatforum.com
navigate to the 'cooling' section and see what ePer thinks you should have.
If fiatforums ePer continues to not work, there is another one here
FIAT ePER :: Fiat Klub Polska
i have seen PH1 and PH2 with both 1 and 2 fans................. obviously they are years old you have no idea what was there when it left the factory as some have been changed over time
mine is PH1 and its twin fan set up
